Rear end grinding noise 68 Shelby GT500
Started by Layne Murphy, February 23, 2020, 05:42:01 AM
KR Convertible
I'm not sure I would trust your specialist.  Thousands of people have done the T5 swap without issue.  If you take a measurement from the trans mount to the center of the output shaft, I doubt it's much different.
Are you sure your driveshaft is the correct length?  If the yoke is too far in, or not far enough, that will cause problems.
pmustang
Hello,  Specialist is "the guy" for axles. Huge name over here
He did say my driveshaft may be a touch short
They pulled the shafts and diff and went over it all and it was "as new"
I will admit I questioned their findings as have had 6 or 8 T5 cars without this issue and mine is an unmolested car so should work as well as any other
The Going Thing
Peter- Can you post the a picture of the trans mount and cross member?
pmustang
Gonna move off this gents post. Hope he gets his issue sorted
Thanks folks,
Peter
