oil pan drain plug
Started by johnzajc@gmail.com, March 01, 2020, 02:00:30 PM
johnzajc@gmail.com
Hi---where oil drain plug painted together with the oil pan or are they actually left natural---after I painted you can no longer see F-C logo-- thanks
Painted with all oil pan attacing bolts and gasket
johnzajc@gmail.com
thank you--so when replacing gasket I gues I should spray gasket before installing since I am nor repainting oil pan
Quote from: johnzajc@gmail.com on March 01, 2020, 02:22:57 PM
And you'll have to figure out how you will address the paint that will likely chip off all the attaching bolts.
For others watching this question relates to 67-70 Shelbys ;)
cbrown
Not to get off topic too much but.  John,  I think the experts will advise the oil pan bolts will have a shadow of how the paint was sparayed and should see some slightly lighter or bare metal toward inner part around bolts and pan .  Also  do you have the correct oil pan with correct baffle as Ed meyer helped advise me and I have had correct baffle made...
chris
johnzajc@gmail.com
Thank you---to get it done even remotely correct I will remove oil pan, strip the paint reinstall , mask the engine and paint it again-- sad part is that I paid to get it work done and know I am redoing it , fortunately I got lot of help from members- THANK YOU ALL        P.S.-if I can give just one advice to next person just starting same endeavour;        Do not ever buy cheap bargain price parts from unknown source, they are to expensive--spend more money and parts from more expensive places, like Meyer parts, Perkings , Bob Gains etc.---- in general guys from SAAC community, you will pay more initially but save money evetually because parts are correct and work--john
