Original Cobra tach
Started by deathsled, March 04, 2018, 09:45:10 AM
deathsled
I never painted my Cobra tach and it still bears the patina from the time the car was bought in the beautiful State of California (I see California with rose coloured glasses, I know, but I still hold the state in high regard as just...dreamy).  My questions are two:
1. Repaint professionally or leave as is with chipped flat black paint?
2. What are the specs on the spacers in the dash for the two screws that hold down the tach and the screw size.  Old post with this info was lost regrettably but I recall the screw heads are pan head and someone suggested (might have been acman) to machine two pieces of aluminum tubes as spacers.  If Acman has repros I will buy.
Thank you all,
Richard E.
Engine revving to disturb
Quote from: deathsled on March 04, 2018, 09:45:10 AM
Depends on the car. Will a restored exterior look out of place once installed?  Or will it make other things in the interior look out of place?
Quote from: deathsled on March 04, 2018, 09:45:10 AM2. What are the specs on the spacers in the dash for the two screws that hold down the tach and the screw size.  Old post with this info was lost regrettably but I recall the screw heads are pan head and someone suggested (might have been acman) to machine two pieces of aluminum tubes as spacers.  If Acman has repros I will buy.
Yes two P&O pan headed Phillips. The use or non-use of the supports would depend on when your car was built (read car number). Something your didn't include ;)
deathsled
pmustang
I had my 66 Tach looked at for an operational fault and I didn't have a thing done to the patina, my car has a tired paint job to match :-)
Quote from: deathsled on March 04, 2018, 02:25:36 PM
6s843 and thank you
Would expect that your car would have had the reinforcements (tubes) originally.
deathsled
Thank you Jeff.  I think acman had a suggestion on the former site about dimensions and how to make.  Or maybe he makes them.  I'll check it out.  And thank you gentlemen, all of your for your input.
Richard E.
A few pictures as usual  ;) to help bolster the thread and rebuild the site to its former glory :)
Sorry for the poor scan
Greg
Quote from: J_Speegle on March 04, 2018, 06:04:57 PM
Jeff, are the spacers (so that the pad doesn't collapse) in the pad itself or a bracket mounted to the metal frame?  Thanks, Greg
Shelby's and Fords from Day 1
Quote from: Greg on March 04, 2018, 06:59:24 PM
The tubes/stands were inserted into the holes made in the dash pad (each are individuals)
SFM6S087
I made some notes when this topic came up on the old forum. Here's what I have:
Those spacers look like short pieces of tubing 11/16" L, 1/2" OD, 1/16"wall. Originals are thought to have been some sort of bakelite material. Ford replacements were made of steel. Repos can be made from 3/8 tubing.
If that's wrong, maybe someone will jump in and correct it.
Steve
GT350Lad
That sounds correct Steve, I took a screen shot of the description on the old forum, I'll try find it but I think your on the money mate  :)
6S373
6S1276
kingchief
I think Jim Cowles reproduces them from time to time.
Steve
SFM 6S406
