What Oil
Started by GT350AUS, March 09, 2020, 04:17:54 AM
427heaven
In my parts they call that a barrel roll. ;D
#31
    Bottom line is that oil becomes a "personal preference" item. Many oils will do the same job and there is allot of "overlap". There are so many different brands to choose from it can be confusing . The thing NOT to do is compare "modern" engine requirements to "older" engines. Oil pumps , bearing clearances , and oil passage design are all different allowing thinner multi weight oils to be NEEDED for top engine performance. I have seen a situation where a "know it all ", 20-50 only oil user took out the 5-20 specified oil for ( you guessed it) 20-50. Not only did he LOSE gas ,mileage and engine performance , poor cold flow caused bearing damage on initial startup.
Side-Oilers
Current:
Previous:
1970 Ranchero GT 429
1969 LTD Country Squire 429
1963 T-Bird Sport Roadster
1957 T-Bird E-model
GT350AUS
Well who would've guessed that this simple topic could've been so informative, interesting and entertaining all at the same time
Thanks to all that contributed and me of course for starting the thread....lol
+ 1 we like you already
A person without a sense of humor is like a wagon without springs. It's jolted by every pebble on the road.
Quote from: GT350AUS on March 10, 2020, 06:13:16 PM
427heaven
Agreed... Wait till you ask how much air pressure is ideal, or what do you think about running a CAUTION fan sticker, the flood gates will open up.
GT350AUS
 :) haha haha I've seen that in Forum version 1.0  :)
Soooo no caution fan sticker hey....hahaha
Speaking of air, should you need vintage air for your tires....we have special containers with the specific air that would be correct for your vintage Shelby.
Please provide us your specific build date and we can provide you with a proper qoute and special SAAC pricing.
Thank you
Quote from: 427heaven on March 10, 2020, 07:02:46 PM
The Going Thing
Quote from: FL SAAC TONY on March 10, 2020, 08:35:26 AM
At this point in my life the discussion of oil is stale. I highly reccomend using fresh Wesson oil, currently on sale at walmart for $6.58 a gallon.
Before I sign off just yesterday my motor developed a klink-klank-ping sound. Would anyone know or care to mention why that is ? klink-klank-ping...
Tony- You've been hanging around in the wrong places in FL again.  This won't get it. You can throw it out.. LOL
Well, the only thing with the oil on the beach, it adds to the Jello effect.
You get more glare depending on whether the Jello is still in the molds or has been released to be free?
    It's the same on any forum. The subject was up on Speedtalk years back and went twenty some pages. All kinds of charts , specifications , personal opinions , no clear result as "one" brand to use. Too many pay attention to advertising claims instead of actual oil performance in use.
The Going Thing
Randy:
Exactly. Or long term use and wear and observation during tear-downs. Mobil 1 absolutely does not contain enough ZDDP to protect a flat tappet cam.
I use Mobil one in my Lincoln and the Saab V6 cars.  I also had an issue with Castrol. I used it on my Turbo Toyota. It would pull enough oil in smoke during high vacuum on deacceleration. I changed to the Kendall and it stopped completely.
Too many personal experiences.   I'll stick with the Penn Grade on the Shelby.
I am not overly enthralled with 18-20 PSI at Idle hot and 55PSI hot at 3000 +-.
427heaven
An average man, doing average things, with an average car, doesn't need to worry about much these days. Turning 10,000 rpm with a 500 ci pro stock engine, or having a Cobra automotive built VOGT engine turning those rpm s for an hour changes the story some. ;)
Quote from: 427heaven on March 11, 2020, 10:32:23 AM
Obviously you are not from my "neighborhood"?  ;)
The Going Thing
Average man. You must be talking about yourself....
