1966 Idler arm needed, Which supplier?
Started by pmustang, March 18, 2020, 01:06:41 PM
pmustang
Hello Folks,
Need to replace my idler arm on 2170. Very small amount of play but like to keep things fresh
Can you suggest a supplier? Don't need NOS, nor show car correct. Just correct fitting. Branda? Virginia Mustang?
Cheers. Peter
Quote from: pmustang on March 18, 2020, 01:06:41 PM
Hello Folks,
Cheers. Peter
Branda for sure .I am not sure if Virginia stock them.
The bushing can be replaced, would be a better option if you have the OEM idler.
pmustang
Thank you Bob
Charles. I will probably swap and I save all removed parts for a future owner
Nice to know its swappable
S7MS427
I would replace the bushing as both the idler arm and the pitman arm are unique Shelby parts.  Theyr are different in length from the standard Mustang parts.  DO NOT mix the two together.  I think the bushings are the same however.  Some forty years ago when I replaced the one in 817, Moog had a roller bearing replacement which I used.  It's been fine ever since as there was no rubber to rot away.  I'm sure that part has long since been discontinued...
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
Virginia Mustang does have the complete 65-66 GT350 quick steering kit.
If you just need an idler bushing, for a driver the roller bearing kit as mentioned is the way to go IMO. The old Moog kits can still be found, part# K451. Cobra Automotive also carries a kit.
Quote from: s2ms on March 20, 2020, 09:51:06 PM
If I remember in addition to the longer arms Shelby used a different ratio in the steering box - same ratio as PS box but manual.
Quote from: 98SVT - was 06GT on March 20, 2020, 11:57:17 PM
The steering box was part of the special handling package and ordered with that option by SA.
It's the same ratio as P/S, just a different pre-load and a different tag #.
pmustang
Thanks Folks, I ordered an Idler, the correct one, from Tony Branda. Its on the way by container to me now. Cheers. Peter
S7MS427
I think I'd still put the Moog roller bearing bushing (P/N K451) in if you can find one, even with a new idler arm.
Roy Simkins
