GT500 Tribute Build
Started by mlplunkett, March 29, 2020, 07:11:42 PM
pmustang
Very nice project and I think I spy very nice floors
I LOVE blue and when this car showed up on this very forum several years ago I bought it.
Have done a fair amount to it since arrival but nothing to the paint or body.
This should give you some enthusiasm to do your project. Nightmist blue 5 speed V8
mlplunkett
That's exactly the look I'm after right down to the tires. Just need a bigger number on the rocker panel.
I have the set of Osborne manuals in fact I had forgotten that I had them until last week when I was trying to organize all the parts I had on hand. There is no rust on the body but there is a previous repair behind the rear tire, passenger side, that is below standard and the radiator support will need to be replaced due to previous damage so that's my only metal work unless I get a surprise.
mlplunkett
#17
Not much progress other than tear-down, purchase of fiberglass parts, and getting the 428 stroker motor built. Maybe that will give me some incentive over the winter. I plan to paint the heads and water pump to keep them from looking so unoriginal.
557
Quote from: mlplunkett on January 06, 2022, 08:40:44 PM
Glad to hear about some progress. If you are concerned about original looking engine components then be aware that the harmonic balancer is supposed to be semi gloss black.
Little by little does the trick, keep plugging away you cash do it
Marcus Aurelius
Our pronouns are We Won
"Usque Ad finem"
mlplunkett
[/quote] Glad to hear about some progress. If you are concerned about original looking engine components then be aware that the harmonic balancer is supposed to be semi gloss black.
[/quote]
Thanks Bob. The builder didn't put a lot into the paint so I plan to strip off the blue and start over. I'll correct the balancer in the process.
